2 hdhomerun
I install 2 different hdhomerun, both work well when install alone, but when I installed both, there is always one that says “Unable to tune channel (No parts)” both have different channel from different antenna, and work like a charmed on HDHOMERUN application switching from one channel to the other with no problem.
What types are these two HDHomerun tuners? Are they the same, or different models?
2 different hdhomerun connect quatro so basically 8 tuner
Mmm revert back to server 1.11.3.4803 from1.12.0.4829 on a mac, and now everything work perfectly
I bet if you keep them installed, and update PMS from there, they will continue to work. (fingers crossed)
yeap it work but downloaded the new server form the download page, and it’s 1.12.1.4885
