2 Plex servers, 1 not found
Hello there,
Ive been testing Plexconnect now and installed it on our primary PMS server with 0.9.8 multi user release on IP which ends on .5.
When running Plexconnect (in the settings i set the PMS to .5) I see this:
PlexConnect : IP_self: xx.xx.xx.5
PlexGDM : ***
PlexGDM : looking up Plex Media Server
PlexGDM : ***
PlexGDM : servers discovered: 1
PlexConnect : PMS: xx.xx.xxx.25:32400
Basically, it only finds the second PMS server (which is on .25 IP).
Plexconnect wont find PMS, which is installed on the same server as where Plexconnect is running from.
Any idea how this is possible? (GDM is active). In settings.cfg i have set ip_pms = xx.xx.xx.5
This seems to have fixed itself by restarting PMS, strangely enough.
...but still only one server is supported.
Ok, so what does that mean? Removing one server?
No... currently you can only access one from PlexConnect.
And the one may vary with ever PlexConnect restart - you will see the first own that called "Good Day Mate...".
To at least fix to one PMS, disable GDM in settings.cfg and put in the IP of the one you like...
