2 PMS 1 ATV3 - PLEXCONNECT
Is this possible?
Yes, plexconnect will discover via plexgdm or myplex
Please help me understand…
I just install plexconnect on the second mac or pc and plexconnect will detect trailer.cer already installed on my atv3?
May I need to change only the dns?
Thank you for your help, I’m a newby.
No you only need one instance of plexconnect, it can connect to multiple pms
Even if the first pc is off?
The machine running plexconnect needs to be always on, that’s the nature of plexconnect. If you wanted plexconnect in both machines you would have to use the same certificates but you would be swapping the DNS setting everytime you changed instances of plexconnect.
This is what I needed to know!
Thank you very much…I’ll try asap
IT WORKED!!thank u soooo much…
Bye
