2 versions of same movie each in their own library causes artwork to disappear
Server Version#: 1.20.1.3213
Player Version#: ALL
Hi.
I have 2 movie libraries on my Plex server. One is for SD-1080p movies and one is for 4K movies only. I have duplicates for each movie in the 4K library in the SD-1080p library as well.
My problem is that I lose artwork in the either the 4K library or the SD-1080p library. It will show artwork in only one or the other. If I fix the problem, it soon happens again.
Any ideas?
I believe I remember having seen that behavior before… but it’s been some time (working fine for me at the moment).
Back then editing and saving the item with the broken poster in Plex had fixed this for me (no changes… just opening it and saving it). I suppose it shouldn’t happen but it used to be an easy fix :wink:
