Plexamp Release Notes
Plexamp v4.50.21-beta.24
Desktop is on the beta channel now, and mobile is on its way to TestFlight and Play testing. The main one: the iPhone Duo’s outer display gets a proper player layout.
Fixed
  • iOS: on the iPhone Duo, the player is centred on both displays, lyrics are no longer cut off, and landscape on the outer display fits every control.
  • Lyrics fade out at the top and bottom instead of showing a sliver of a cut-off line.
  • Lyrics show on the first try after reopening the app.
