Plexamp Release Notes
Plexamp v4.50.21-beta.26
Mobile is on its way to TestFlight and Play testing, and desktop is on the beta channel. The main one: Signal Path, which used to work only when playing to a Caldera player, now works for music playing in Plexamp itself.
Added
  • Signal Path for music playing in Plexamp, not just on a Caldera player: tap the light by the codec details to see each step from file to speaker, and what keeps it from being lossless.
Fixed
  • After switching networks, screens load straight away and relayed servers connect sooner.
  • CarPlay/Android Auto: a new track’s artwork shows straight away, on the lock screen too.
  • iOS: an unfolded iPhone Duo no longer sometimes sticks on the logo at launch.
  • iOS: on the iPhone Duo’s outer display, the visualiser reaches both edges again.
  • Desktop: resizing a window no longer switches between Desktop and Compact; use the Window menu or the shortcuts.
