Plexamp v4.50.21-beta.28
Desktop is building for the beta channel now, and mobile is on its way to TestFlight and Play testing. beta.27 never went out, so its fixes are in this one too.
Added
- Windows: Previous, Play/Pause and Next in the taskbar button’s preview.
- Desktop: long-pressing Home in the sidebar refreshes it.
Fixed
- Music is no longer resampled to the device’s old rate and back after a rate change, or after a long pause with Sample Rate Matching off.
- Signal Path shows the rate the device really outputs at, and calls a lossy source Lossy.
- Signal Path shows each change once, explains DSD as converted to PCM, and shows Volume Leveling even at 0 dB.
- Opening an album or playlist with a track the server hasn’t analyzed no longer crashes.
- A fully downloaded smart playlist keeps all its tracks on refresh, and scrolls without stalling.
- With Prefer Downloaded Media on, a downloaded track plays from its download.
- The player shows a downloaded album’s cover straight away.
- The Autoplay card in Up Next stays put as you remove tracks near the end of the queue.
- iOS: on cellular over a VPN, the Cellular streaming quality applies again.
- iOS: on a folded iPhone Duo held sideways, menus keep clear of the camera and a playlist’s title no longer covers its artwork.
- iOS: on an iPad, a long album title no longer slides under the navigation bar.
- Mobile: held sideways, a player menu’s header no longer runs into the notch.
- Desktop: the Autoplay row in Up Next shows its arrows when you hover over it.
- Desktop: the tray menu keeps to showing the window and choosing its mode.
- Windows: Signal Path shows WASAPI’s real bit depth, and says when it has the device to itself.
- Windows: a maximized or full-screen window stays that way.
- Windows: no more crash playing to another player with the visualizer showing.
- Windows: the installer shows the Plexamp icon.
