Plexamp v4.50.21-beta.33
Desktop is building for the beta channel now, and mobile is on its way to TestFlight and Play testing. beta.32 went out on desktop and iOS only, so its changes are in this one too. The main one: you can pin things to the top of Home.
Added
- Pin albums, artists, playlists and stations to the top of Home, in your own order, and they sync to your other devices. Pin from an item’s menu or its page, and arrange them with Edit.
- CarPlay/Android Auto: your pins show first on Home.
Fixed
- Download on an album that Keep Played Music saved now keeps it as a real download, instead of saying it’s already downloaded.
- Signal Path shows no bit depth for a lossy track, since it has none, and shows its decoder producing 32-bit float.
- iOS: on the iPhone Duo, menus end beside the clock and camera instead of running under them.
