Plexamp v4.50.21-beta.43
Desktop is out on the beta channel now, and mobile is on its way to TestFlight and Play testing.
Added
- On a tablet or the desktop, an album’s page shows its styles and record label under the year; tap one to see your other albums that share it.
- Signal Path names the original format of a track the server converts, such as DTS 5.1, and says why.
Fixed
- Tapping a track in Up Next no longer sometimes plays the one after it.
- Tapping a downloaded track that’s also on another downloaded playlist or album queues the one you’re looking at.
- Choosing Silence after an album is respected again, and jumping to an album’s last track no longer starts a mix you didn’t pick.
- Deleting a download stops its tracks that are still downloading.
- The signal path light and its popup work while controlling another Plexamp.
- While casting, the time stops at the end of the track if the phone loses touch with the speakers.
- The Spectrum visualizer’s bars all have the same clean gap between them.
- Desktop: links in text (artist names, the year, styles, labels) get the same soft highlight under the pointer.
- macOS: playback pauses when the Mac goes to sleep, so a closed laptop no longer shows as playing or starts again by itself.
- Windows: device names with apostrophes and accents show correctly in Signal Path and the output list.
- Linux: on NVIDIA under Wayland, the app no longer closes by itself or crawls when scrolling, and draws on the GPU again.
- iOS: Signal Path shows AirPlay 2 as lossy, and classic AirPlay as 16-bit.
- iOS: CarPlay no longer sometimes shrinks the album name to a single letter.
- Android: downloads keep going in the background past the first 40 tracks, and pause off Wi-Fi rather than stopping.
