2K Resolution
I’ve started making a 2K (2560x1440) resolution movies from my 4K sources for streaming. The Playback UI shows the resolution of 1080p. Can Plex be updated to show 2K sources? Is there a file I can change to add additional resolutions.
Are there any devices using this resolution? I don’t see any reason using this exotic resolution.
Me either, unless I’m wearing my Gaming Hat, and if the vertical resolution is lower than 1080 - be happy Plex isn’t calling it 720.
“2K” isn’t what you want. If you do, you want 1080p - it has more vertical resolution.
“4K” is what you want. - it’s better than 1080 - and whatever 2K is supposed to be.
OK - we’re gonna call it:
QHD - and wonder what niche resolutions are going to do for me - other than confuse Plex.
Yea, Tom’s isn’t exactly the Library of Teckno-Congress, but I think we’ve seen enough here to move along… and unless you’re encoding, or seeing a whole lotta black bars everywhere - all you’re doing is destroying the aspect ratio, or cropping out giant hunks of image and you’ll find no love for that here among us ‘Purists’.
:wink:
I’m resizing. Not cropping the image other than the black bars. Dong some reading and it seems that even 1080p could also be called a 2K resolution (1920 being close to 2000), then perhaps it’s better to just use the 720p, 1080p, 1440p, 2160p, etc. So can 1440p be added to the definitions or is there a file I can modify to get that resolution to display in the UI?
You can’t. You’ll depend on Plex to add this to the underlying system.
