Hi, i found some small design problems in the mobile app.
- At the mobile app you can’t see your actual playlist in the music player.
- In landscape view you can’t switch or select the libraries.
- Libraries - Browse overlapping header? in portrait view
Dropbox - File Deleted
Dropbox - File Deleted - The alphabet jumplist doesn’t appear if i press at the letter, but it appears if i press right from the letter.
The app looks and feels great on mobile, big thanks guys
