Hey, sorry but I’ve some more bugs:
- The music player no longer plays music. Whether from the server or synchronized. If I start the music it just stays on 0:00 and nothing happens.
- If I go TV Shows->Any TV Show->Seasons Page results everytime in an Unexpected Error.
- If you switch to “This Device” and go into the Artist Page of an music library, you have a full coloured artist picture as Background (and on the music player).
- On Mobile sometimes these small popups appears without making sense.
Just as an example “Plex”: https://www.dropbox.com/s/zrxk9ez1b0mnjnx/wp_ss_20160913_0001.png?dl=0
- (I had this bug before 3.0.66, I think it’s still in there) Synced music (flac) which gets converted seems to damage the timeline. All songs are shown as ~30-60 seconds long.
Wouldn’t it make sense on Windows 10 (mobile) to give the option to sync flac and mkv as original without converting?
- On the “User Selection” screen the upcoming numpad pushes the login upwards and the “Enter Pin” gets halved.
Hi, thanks for the observations, see below:
This will be fixed in the 3.0.67 release being pushed to the store.
Can you please take a log with 3.0.66 or later and send it to me?
We have the option to enable hardware blurring if the device is running Windows 10 AU, at the expense of more resources being used. We could perhaps enable this on higher spec devices.
This is the tooltip that normally shows up on Windows desktop. Since Windows Mobile can now have focus on items like Desktop (due to Continuum), by default those tooltips show when an item gets keyboard focus. We’ll need to see how we can better handle that in the future, but for now there are higher priorities, of course.
Haven’t seen this, will try to repro.
Yes, definitely. Again, it is just a question of time to implement and thoroughly testing the implementation.
Will try to improve the occlusion detection logic here.
Regarding the tooltips, in 3.0.67 that should now show correctly based on the platform (so it’ll show on desktop and continuum, but not mobile).
I tried syncing a FLAC file and it synced correctly to ~7 minutes length. There must be some other factor to that.
If I remember right, it was just in the music player the moving bar when it was played. The music still plays but the bar was at its end after ~30 sec.
I’ll have a look when the next version is here and the music player works again.
I’ve tested it again [3.0.67] with different flacs and options, I have this bug everytime.
On Server → After Sync and converting on phone
@Martin.S do you think you could send me one of the files so I can test?
