I am running 4 different Plex servers all on windows and dont have any of these issues. Are you trying to run plex as a service? have you ever opened Plex as an admin? (BAD IDEA)
@Yaracuy been dealing with end user support for different things for over 20 years now. In most cases what you are seeing is the frustration venting over an issue that the user has been attempting to deal with by themselves unsuccessfully. Once the steam is released often times things become much more civilized.
If you want to do this on your own, I can offer this.
It runs on the native host (Linux) or inside the container environment to talk to Plex.tv (needs a working DNS and Gateway) and get credentials setup.
Once the script and Plex.tv communicate (regardless the LAN IP addressing – which is often a problem), you’ll be able to access it provided the PMS server is on a RFC-1918 LAN or hosted in a data center
Virgin install. 24 hours old. Nothing done. OOTB. One single reboot F$&%s it up. For $11 per month and a defective product, you would be uncivilised as well, especially as I have been using Plex for well over a decade, on and off.
Agree with @ChuckPa to back down to the public release.
Uninstall Plex Media Server via standard Windows uninstall. This will remove the Plex application, but not the Plex Data Folder. Do not use Revo, CCleaner, or similar tools.
Reboot the PC.
Download and install the current public release, v.1.42.2.10156.
See if you can login, access libraries, etc.
If you still have problems, update the thread and include a new set of server log files.
Was running production release. Thought I would try Beta. Exactly the same issue. Works until reboot count > 0. I will go back to prod. And no Windows cleaning tools. I will leave %localappdata%, and registry entries. I’m in I.T. (on the tools), so you can be as technical as needed.
Uninstalled Beta. NO cleanup performed as suggested by @FordGuy61 . Installed prod release. REBOOT count = 0. Plex is seemingly FULLY FUNCTIONAL. Server logs:
I’ve used Plex for many years and it has really been working great! However, the last restarts of my server has ended up in this issues occuring. It’s really frustrating since nothing has de facto changed in regards to my setup, except for regular windows updates.
I wasted an hour trying to solve this on a new setup, then I saw an article that Plex is blocking Hetzner IP ranges. Keep this in mind. I regret paying for a pass now. Might be time to look at other options instead of Plex. What a disappointment and waste of time, especially because you don’t even get a helpful message, just 401.
