404 when fetching .deb from repository
I’m getting the same issue on Raspbian GNU/Linux 10 (buster), see below (executed at 18:33 BST):
sudo apt-get install plexmediaserver -y
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following packages were automatically installed and are no longer required:
libexiv2-14 libgfortran3 libgmime-2.6-0 libmicrodns0 libncurses5 libssl1.0.2 rpi-eeprom-images uuid-dev
Use ‘sudo apt autoremove’ to remove them.
The following packages will be upgraded:
plexmediaserver
1 upgraded, 0 newly installed, 0 to remove and 270 not upgraded.
Need to get 76.9 MB of archives.
After this operation, 13.6 MB of additional disk space will be used.
Err:1 https://downloads.plex.tv/repo/deb public/main armhf plexmediaserver armhf 1.22.3.4523-d0ce30438
404 Not Found [IP: 104.18.12.47 443]
E: Failed to fetch https://downloads.plex.tv/repo/deb/pool/plexmediaserver_1.22.3.4523-d0ce30438_armhf.deb 404 Not Found [IP: 104.18.12.47 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
PEOPLE ???
PLEASE READ MY POSTS ??
Thank you for your consideration.
This is good news. Do you have any sort of basic timeframe on when the next deploy action will be? Like a day or a few days or a week, etc…
It worked for me. I was able to update to 1.23.2.4656. I didn’t change anything, just did the usual update procedures and it found and successfully installed the update.
Thanks!
Problem is now resolved for me too. Thanks to everyone who helped!
Thanks @ChuckPa I’ve just managed to update Plex on my DietPi instance.
great work plex dudes and dudettes! all back to kicking ass! :grin:
Works here too! Thanks for resolving this!
