4k direct play problems
Hi
I am having a problem with plex app on windows 10 (Kaby lake I3 7100) and xbox one-s and samsung tv. When playing a 4k mkv around 70GB movie it starts to play bad like its pausing and playing in seconds , I can confirm that I tried playing the same file over the Network the same PC using kodi (not plex app for kodi just kodi)using the same server but via smb share and it plays fine, so what could be happening to the plex app ? thanks regards
File info
Video Resolution 4K
Duration 2:15:57
Bitrate 52127 kbps
Width 3840
Height 2160
Aspect Ratio 1.78
Container MKV
Video Frame Rate 24p
Audio Profile ma
Video Profile main 10
Part
Duration 2:15:57
File The Fate of the Furious (2017).mkv
Size 49.50 GB
Audio Profile ma
Container MKV
Has Thumbnail 1
Codec HEVC
Bitrate 50207 kbps
Language English
Bit Depth 10
Chroma Subsampling 4:2:0
Color Range tv
Color Space bt709
Frame Rate 23.976 fps
Height 2160
Level 5.0
Profile main 10
Ref Frames 1
Width 3840
Forced true
Codec AC3
Channels 5.1
Bitrate 384 kbps
Language Português
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Codec DCA
Channels 7.1
Bitrate 1536 kbps
Language English
Audio Channel Layout 7.1
Bit Depth 24
Profile ma
Codec SRT
Format SRT
wow paying plex pass and not a pinch of help.
Anyway the app is not using the GPU its using the CPU thats why I am getting this problem as Kodi is using the gpu, is there no support for this in plex app?
