[duplicate of other issues, but was asked by Plex on Twitter to create a topic with logs attached]
Server Version#: 1.18.6.2350 (on a WD My Cloud Home)
Player Version#: 2.52.1.70
Output from ffmpeg -i:
Input #0, mpegts, from 'z:\Plex\Shared Movies\Trailers\Pufferfish.m2ts':
Duration: 00:00:43.39, start: 11.650667, bitrate: 75907 kb/s
Program 1
Stream #0:0[0x1011]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc
Stream #0:1[0x1015]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc
Stream #0:2[0x1100]: Audio: truehd (AC-3 / 0x332D4341), 48000 Hz, 7.1, s32 (24 bit)
Stream #0:3[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/s
Stream #0:4[0x1101]: Audio: eac3 (AC-3 / 0x332D4341), 48000 Hz, 7.1, fltp, 1664 kb/s
Stream #0:5[0x1102]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/s
Surprisingly, the files plays ok via DLNA from Plex server to Xbox Oneâs âMedia Playerâ app seemingly without transcoding, but not on the Plex app. It seems Plex server would like to transcode it?
Logs after Plex app fails to play the file:
Plex Media Server Logs_2020-04-21_22-13-49.zip (956.2 KB)
Logs after Xboxâs Media Player surprisingly successfully plays the files via DLNA:
Plex Media Server Logs_2020-04-21_22-30-36.zip (979.7 KB)
Note: I also tried VLC as well, but it could play the audio only, but had black picture. My TV is only 1080p, so the Xbox is downscaling.
