Forum logs upload should be fixed. Forum provider virus checker broke
No dice, I tried playing Tenet through my iPhone with the hardware tone mapping turned on and the same result, the transcoder drops down to using software and uses up 60% of my CPU as before. Image looks good though. I donāt see any obvious errors in my logs though. The logs seem to indicate it thinks it has hardware and lots of lines saying HEVC 10-bit test passed it seems. I did notice an error on install saying I need the beignet package installed, but I have the neo opencl packages installed instead as beignet doesnāt support Rocket Lake. But as I understand it, I donāt even need opencl as the new Gen12 graphics have tone mapping support built-in to the VAAPI drivers now?
OHHH! I tried turning the tone mapping setting off again and I no longer get the corrupted video I did before. The colors are obviously messed up without the tone mapping, BUT I am no longer getting corrupted video as I did before, and its showing up with the (hw) tag now with barely any CPU usage. So a step in the right direction! Just need to fix the tone mapping to also use the hardware and we will be golden!
Iām in the same situation with an i5-11500. Running on Unraid though, but still Linux. Got to the (hw) working and it seems itās working with tone mapping on non hdr (10 bit) content. But when itās hdr 10-bit with tone mapping on it will just software decode.
The same situation happens in Emby though. So I wonder if itās not some kind of ffmpeg or Linux specific issue.
I believe this is the same issue as here and some confusion as to why a second thread was created.
I posted my problem in that exact thread but was asked to create a new thread, so that is why this exists.
Thanks a lot for these clarifications⦠I went through a clean up cycle, added the Intel PPA, added the packages you listed and vainfo reports correctly now:
root@ubuntu02:~# vainfo
error: XDG_RUNTIME_DIR not set in the environment.
error: can't connect to X server!
libva info: VA-API version 1.10.0
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_10
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.10 (libva 2.10.0)
vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 21.1.2 (67dbfde)
vainfo: Supported profile and entrypoints
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : VAEntrypointStats
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointFEI
VAProfileH264Main : VAEntrypointEncSliceLP
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointFEI
VAProfileH264High : VAEntrypointEncSliceLP
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointFEI
VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointFEI
VAProfileHEVCMain : VAEntrypointEncSliceLP
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointEncSliceLP
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile1 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileVP9Profile3 : VAEntrypointVLD
VAProfileHEVCMain12 : VAEntrypointVLD
VAProfileHEVCMain12 : VAEntrypointEncSlice
VAProfileHEVCMain422_10 : VAEntrypointVLD
VAProfileHEVCMain422_10 : VAEntrypointEncSlice
VAProfileHEVCMain422_12 : VAEntrypointVLD
VAProfileHEVCMain422_12 : VAEntrypointEncSlice
VAProfileHEVCMain444 : VAEntrypointVLD
VAProfileHEVCMain444 : VAEntrypointEncSliceLP
VAProfileHEVCMain444_10 : VAEntrypointVLD
VAProfileHEVCMain444_10 : VAEntrypointEncSliceLP
VAProfileHEVCMain444_12 : VAEntrypointVLD
VAProfileHEVCSccMain : VAEntrypointVLD
VAProfileHEVCSccMain : VAEntrypointEncSliceLP
VAProfileHEVCSccMain10 : VAEntrypointVLD
VAProfileHEVCSccMain10 : VAEntrypointEncSliceLP
VAProfileHEVCSccMain444 : VAEntrypointVLD
VAProfileHEVCSccMain444 : VAEntrypointEncSliceLP
VAProfileAV1Profile0 : VAEntrypointVLD
VAProfileHEVCSccMain444_10 : VAEntrypointVLD
VAProfileHEVCSccMain444_10 : VAEntrypointEncSliceLP
I havenāt tried the developer build yet - waiting for clonezilla to finish.
thanks @RoadRacer12, @ChuckPa
10700k here, same issue. Rolled back to v1.21.3.4046 and Iāve got HW tone mapping back. Using Linuxserver.io docker on Unraid.
Iām using the same version since I did a rollback a week ago. Strange is that today thereās an update for my Plex docker in Unraid, even though Iāve locked the docker to only use that version, not ālatestā or āstableā or something like that, but only that version.
Whatās about that?
Still no 4K HDR HW transcoding with āEnable HDR Tone Mappingā Checked ON
Iām running a newly built UNRAID 6.9.2 server with an Intel i7 10700 CPU. No GPU card. Iāve been trying to get the Quicksync iGPU transcoding to work with 4K HDR files.
iGPU HW transcoding works with 1080p Files
iGPU HW transcoding works with 4K HDR files, BUT WITH TONE MAPPING CHECKED OFF
iGPU HW transcoding FAILS to work with 4K HDR files, WITH TONE MAPPING CHECKED ON. In this situation, the transcoding falls back to the CPU and I get heavy CPU Usage.
The plex docker version is 1.22.2.4282.
Is there anything I can tweak to make this work, or is this still a PLEX issue?
Thank you.
for now I use linuxserver/plex:version-1.22.0.4163-d8c4875dd and disabled updates
Unfortunately, that is not an option for me as it results in corrupted video on my Rocket Lake iGPU. Hopefully they can get the HW HDR->SDR working on the Rocket Lake processors soon. For now, I am just using the latest with HW HDR->SDR turned off and dual media files. (1080p and 4K HDR files for each movie)
I use the same version in Unraid (set the version to ā1.22.0.4163-d8c4875ddā in the version box), but since 3-4 days my docker in Unraid says thereās an update. Do you have the same? Or is it correct that there shall be an update, even though Iāve specified an exact version?
/Sƶder
Thatās an interesting difference between our 11th gen systems. My system will transcode from 4K (with tone mapping off) so I donāt need additional 1080p files.
Are you having the 1080p files because thatās your normal transcoding target format? Could you explain the reasoning behind needing both?
Iām locked on 1.22.0-4163 until a new version is widely hailed as having fixed this problem⦠(someone get these plex devs some 11th gen hardware!
I keep both files right now so I can leave tone mapping off and not have the movie look like crap when streaming remotely. Iām sure you have noticed the colors are WAY off when tone mapping is off? Once HW tone mapping is working again, I wonāt need the 1080p files anymore.
Plex team,
When can we expect a Plex server release for linux that reenables HW HDR->SDR transcode on Rocket Lake?
1.22.0.4163 does not work for me, HW HDR-SDR works but I get corrupted video as I posted an example frame grab above.
1.23.0.4320 also does not work for me, HW HDR-SDR does not work.
1.22.3.4392 also does not work for me, HW HDR-SDR does not work.
Also Plex Team
When can we expect a new Plex version to use Quicksync/iGPU HW 4K HDR -->>SDR Transcode on a Intel 10700?
Thatās being done in different threads and theyāre tracking that, too.
@timstephens24 ⦠could you post links to those threads here?
thanks in advance
