4K playback on TCL TV
Server Version#: 1.25.5.5492
Player Version#: 8.30.0.30944
I have 2 TCL Smart Android TVs, one is a C725 and the other is a C825.
The C825 does 4K playback perfectly. On the C725 it will only do 1080P. If is use Kodi with the Plex plugin 4K playback works perfectly.
Adam
The C825 has (WiFi 6 – 802.11ax)
The C725 has 2.4GHz/5GHz dual-band Wi-Fi 802.11 b/g/n
Wired, both are 100 Mbps limited.
With the C725 , suspect you do not have fast enough networking for some of the 4K content (300 Mbps total max - 150 Mbps typical) with 802.11n
I have LG C1 (2021) and had to upgrade the WiFi
Does not explain why using Kodi on the C725 I can do perfect 4K playback. It’s only the Plex app that is limited.
Actually,
  1. Kodi is connected with Gigabit ? (wired or WiFi/802.11ac ?)
  2. It’s connected to the TV directly over HDMI ?
“Perfect Playback” – Please qualify that?
– What bit rate(s) ?
– subtitles ?
– CPU?
DEBUG logs will explain everything because subtitles have a huge impact.
Chuck,
Both Kodi and Plex are both apps on the TCL TV. The TV is connected via wireless and Kodi reports the stream as 6.4Mbps 4K(Original).
I do not have subtitles enabled and there is no stuterring or caching of the stream once started.
Adam
Thank you! That explains a lot. When you said Kodi, I immediately thought of the Kodi HTPC connected over HDMI.
I apologize . My knowledge of Kodi is that dated.
I unfortunately can’t help much.
I have a LG C1 (2021) which is on WiFi 6 and is flawless with the Plex app even at 59.94 FPS
So I have resolved this issue by a firmware upgrade on the TV itself. I upgraded from Android TV to Google TV and the issue has resolved itself. I have noticed that the H264 max level has increased to 5.1 from 4.2.
