Ok. Recently my 4K movies have been playing from my PC to my TV with no problem but I noticed it was buffering today but I noticed also somewhat a friend was also watching a movie from a different location will that slow my 4K movie Down
need Debug logs to see whats happening. recreate & capture just after it buffers the second time. attach the zip it gives you here
“type”: “info”,
“host”: “127.0.0.1:32400”,
“userAgent”: “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/63.0.3239.84 Safari/537.36”,
“browser”: {
“id”: “chrome”,
“name”: “Chrome”,
“version”: “63.0”,
“webkit”: true,
“platform”: “Windows”,
“platformID”: “windows”,
“platformVersion”: “10”,
“platformModifierKey”: “ctrl”
“version”: “3.20.8”,
“primaryServerUrl”: “https://192-168-0-5.bbce32a0c5354fac80fdf6bad1c1b232.plex.direct:32400/”,
“primaryServerAuthToken”: true,
“username”: “Pittro124”,
“cloudUrl”: [
“scheme”: “https”,
“address”: “plex.tv”,
“uri”: “https://plex.tv”,
“testState”: “connected”,
“isBundled”: false,
“isFallback”: false,
“relay”: false,
“isPossiblyCrossNetworkProtected”: false,
“isUntested”: false,
“isPending”: false,
“isConnected”: true,
“isUnauthorized”: false,
“isUnavailable”: false,
“isFailed”: false,
“isAborted”: false,
“isLoopback”: false,
“isPrivate”: false,
“isHttps”: true,
“isSecure”: true,
“isPlexDirect”: false,
“currentTest”: null,
“sources”: [
“id”: “internal”
“type”: “log:message”,
“level”: 2,
“message”: “[Companion] Poll connection successfully opened with DESKTOP-12M4Q39”,
“time”: “2017-12-23T03:40:31.606Z”
“type”: “navigation”,
“route”: “logs”,
“args”: [
null
“fragment”: “#!/logs”,
“time”: “2017-12-23T03:40:34.887Z”
“level”: 2,
“message”: “[Companion] Opening long poll to DESKTOP-12M4Q39 at https://192-168-0-5.bbce32a0c5354fac80fdf6bad1c1b232.plex.direct:32400/player/proxy/poll”,
“time”: “2017-12-23T03:40:46.749Z”
“type”: “ajax”,
“url”: “https://192-168-0-5.bbce32a0c5354fac80fdf6bad1c1b232.plex.direct:32400/player/proxy/poll?deviceClass=pc&protocolVersion=1&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1&X-Plex-Product=Plex%20Web&X-Plex-Version=3.20.8&X-Plex-Client-Identifier=5aiss6efcygwpngiev6sa4r1&X-Plex-Platform=Chrome&X-Plex-Platform-Version=63.0&X-Plex-Device=Windows&X-Plex-Device-Name=Plex%20Web%20(Chrome)&X-Plex-Device-Screen-Resolution=1368x821%2C1368x912&X-Plex-Token=TOKEN”,
“status”: 200,
“headers”: {
“Accept-Language”: “en”
“responseLength”: 0,
“time”: “2017-12-23T03:40:46.753Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:40:46.754Z”
“level”: 2,
“time”: “2017-12-23T03:40:51.758Z”
“level”: 2,
“time”: “2017-12-23T03:41:06.844Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:41:06.846Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:41:06.847Z”
“level”: 2,
“time”: “2017-12-23T03:41:11.846Z”
“level”: 2,
“time”: “2017-12-23T03:41:26.920Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:41:26.928Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:41:26.930Z”
“level”: 2,
“time”: “2017-12-23T03:41:31.926Z”
“level”: 2,
“time”: “2017-12-23T03:41:47.089Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:41:47.093Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:41:47.094Z”
“level”: 2,
“time”: “2017-12-23T03:41:52.091Z”
“level”: 2,
“time”: “2017-12-23T03:42:07.292Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:42:07.294Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:42:07.295Z”
“level”: 2,
“time”: “2017-12-23T03:42:12.298Z”
“level”: 2,
“time”: “2017-12-23T03:42:27.343Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:42:27.346Z”
“type”: “ajax”,
“status”: 200,
“headers”: {
“time”: “2017-12-23T03:42:27.347Z”
“level”: 2,
“time”: “2017-12-23T03:42:32.357Z”
I’m sorry, I should have been more specific.
Settings - Server - Help - Down Logs
Please attach the zip file it gives you
here it is
Any help would be great…
Thanks for the logs.
It’s a bit confusing since both “E.T” and “Transformers” are starting at the same time on what appears to be the Samsung (ZID00_X6 ?) and Android ?
The logs also show you don not have Direct Streaming (for audio) enabled
PMS also sees your TV as 1920x1080 (2K) and not HEVC capable and must therefore convert to MPEG2-TS
Dec 22, 2017 22:25:08.184 [4724] DEBUG - Scaled up video bitrate to 262674Kbps based on 4.500000x fudge factor.
Dec 22, 2017 22:25:08.184 [4724] DEBUG - Scaled maximum bitrate for resolution reduction to 65668Kbps.
Dec 22, 2017 22:25:08.184 [4724] DEBUG - Codecs: testing mp3_mf (encoder)
Dec 22, 2017 22:25:08.184 [4724] DEBUG - Codecs: testing aac_mf (encoder)
Dec 22, 2017 22:25:08.184 [4724] DEBUG - MDE: Selected protocol hls; container: mpegts
Dec 22, 2017 22:25:08.184 [4724] DEBUG - MDE: analyzing media item 36577
Dec 22, 2017 22:25:08.185 [4724] DEBUG - MDE: E.T. the Extra-Terrestrial (1982): Direct Play is disabled
Dec 22, 2017 22:25:08.185 [4724] DEBUG - MDE: E.T. the Extra-Terrestrial (1982): media must be transcoded in order to use the hls protocol
Dec 22, 2017 22:25:08.185 [4724] DEBUG - MDE: E.T. the Extra-Terrestrial (1982): selected audio stream is not the first audio stream and direct play stream selection is not enabled
Dec 22, 2017 22:25:08.185 [4724] DEBUG - MDE: E.T. the Extra-Terrestrial (1982): no direct play video profile exists for http/mkv/hevc
Dec 22, 2017 22:25:08.185 [4724] DEBUG - MDE: E.T. the Extra-Terrestrial (1982): no direct play video profile exists for http/mkv/hevc/dca
Dec 22, 2017 22:25:08.185 [4724] DEBUG - E.T. the Extra-Terrestrial - video.width limitation applies: 3840 > 1920
Dec 22, 2017 22:25:08.185 [4724] DEBUG - E.T. the Extra-Terrestrial - audio.channels limitation applies: 8 > 2
Dec 22, 2017 22:25:08.185 [4724] DEBUG - MDE: E.T. the Extra-Terrestrial (1982): Direct Streaming is disabled, so video stream will be transcoded
Dec 22, 2017 22:25:08.185 [4724] DEBUG - MDE: E.T. the Extra-Terrestrial (1982): no remuxable profile found, so video stream will be transcoded
Dec 22, 2017 22:25:08.185 [4724] DEBUG - Codecs: testing h264_nvenc (encoder)
Dec 22, 2017 22:25:08.185 [4724] ERROR - [FFMPEG] - Cannot load nvcuda.dll
It looks like you have playback quality limited to 20 Mbps for a video (E.T.) which is of much higher quality (~65 Mbps w/ audio) and forces the HW transcode to reduce to 20 Mbps (per the TV’s playback limitation or the remote upstream limitation.
Hardware-wise , you have more than enough throughput capability with the computer and DirectX-coupled GPU.
This having been said, can you confirm / help determine where the limited settings are coming into play?
- Upload set to 20 Mbps?
- TV (or both) set to 20 Mbps?
- Direct Streaming disabled?
- HEVC source video ?
- Television(s) / players are not HEVC compatible?
May I see the full XML of those two movies ? (hover over them, expose ellipsis, Get Info, View XML)
Copy/Paste each in your reply, put a blank line above and below each block, Then highlight each block of text with your cursor and, using the Paragraph formatter button at the top of this reply window, select Code paragraph formatting so the forum doesn’t eat it?
1st where is the setting for Direct Streaming (for audio) enabled ? …at the time i see a friend was watching a movie which i stopped… it still buffered…im trying to run on a 4k samsung tv…ill try again …i changed some settings but still buffers
Which “Plex” app are you using?
One is from Plex, inc and the other (the original “Plex for Samsung” app… which has the audio recording studio graphic) is also available.
plex app for samsung tv
i think i found it…located on samsung app…under audio…DTS [DCA] enabled
was not checked…i checked it…so far no buffering
Gotta love those ‘options’
