I’ve seen a few posts on subtitle issues when playing 4K material. Is there a fix in the works or a known workaround for this?
All of the 4K discs (with subs) that I’ve ripped just won’t play subs correctly. Either they’re completely missing or they’re out of sync.
Would hard coding the subs work? Also wondering if this issue is on the server side or the client (player).
Any help is appreciated.
