Apple Releases Apple TV 6.0.1 Firmware Update
Anyone risked it yet?
I did not risk it yet. Waiting for someone that work on plexconnect to give us instructions on that.
risk it risk it risk it!!..its just a minor update. i don't think apple has changed anything but a few tweaks on performance and stability.... ok I'll take one for the community..Ill report back in a few..wish me luck
yup. still works
I can co-confirm. Plexconnect still working.
I concur, wholeheartedly, it is working for me.
No need to do the trailers key and pem procedure over?
With the last update to 6.0, I had to redo the whole procedure.
I did not have to redo anything. But I didn’t with the 6.0 update either.
OK—I will give it a go.
Thanks.
Guess the navbar bug is still there?
Working normally :)
Working normally :)
the navbar or plexconnect in general?
navbar bug?
What navbar bug? What do you mean? The only bug i'm having is with the sleep ..
I talked about PlexConnect in general
navbar bug?
Still there.
Ok... but this is not the NAV BAR. Let's call it seek- or progress bar.
Nav Bar (as in Navigation) usually refers to the top line main menu, in PlexConnect the "Library Channel Settings" one. Or the on in the movies/tv shows views.
I've updated an ATV2 and an ATV3, both are still working fine. Did not have to install the profile again.
no reason for that ..
just updated my second ATV i got yesterday-all still good
I've just done the 6.0.1 Update and PlexConnect is still happy, Phew/Horay!
