When I am browsing my media and I go up a level (back), the browser goes up two levels. If there isn’t two levels to go up, it returns to the lower level I was in prior. Also, It would be nice if it retain the position in the upper level when going back. ie) If i’m scrolling thru the movies in browse mode and i’m on letter J, it goes back to the browse area as if I just entered. Since back goes up two levels to return to alphabetical browsing I have to do the following: I bring up the (un)watched/delete/goto drop-down menu; and when I go back the first level leaves the drop-down and the second level returns me to alphabetical browsing. I should still be a the J movies but it returns as if I just entered…
This is fairly complicated and you may not understand the description. So if a different description method is needed, please tell me!
I navigate using a MCE 44 button remote in PMP is in full-screen TV mode.
Plex version 13.9.2
Player 2.1.1
OS win10
It’s a clean install. I just re-built this laptop. core i5 6 GB samsung model???
I can get more information if you need more than this.
