Hey!
I downloaded the new beta.
Unfortunately the problem still exists:
My MP3 files are ALWAYS transcoded, although I set the quality to “Original”. As reason for the transcoding Plex mentions “bandwidth exceeded”.
With the stable version of Plex it works without transcoding.
Hi @blueJack92, in order to investigate this, do you mind sharing app logs following https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/ ?
Thanks in advance
These are my log files:
plex-log-blueJack92.zip (393.9 KB)
jesusmc
4
Thanks for the logs, we are investigating it and hopefully will be fixed soon.
Confirming the bug. Regular flac 44.1/16 are transcoded in the local network.
Problem solved with latest build! Thanks!
jesusmc
7
Glad to hear the issue got fixed! Do you mind marking this thread as solved then? Thanks
