I’m looking to buy an 8-bay QNAP NAS and found these two:
TVS-873 (AMD)
TS-853A (Intel)
Does the AMD support harware transcoding if having PLex Pass?
Can I use Docker on both of them?
It looks like in the compability list that the 873 doesn’t do hw transcoding… does the cpu make up for it with sw transcoding or should i go for the 853 model?
I had decent results with my TVS-x73 box when I was running plex on it. This thread talks about the impact of bitrate on # of concurrent streams you can handle.
I ended up buying the TVS-873e (AMD). Works like a charm but on some high bitrate movies I get the occational stutter. I solve it by lowering the bitrate a bit.
