Tried to leverage HW transcoding, still appears with beta4 not to support the TVS-x73 Family (AMD Embedded R-Series RX-421BD Radeon R7).
Here are the errors posted to console:
libva info: VA-API version 0.40.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/dri/radeonsi_drv_video.so
libva info: va_openDriver() returns -1
And here are the errors out of the Plex Logs:
Aug 10, 2017 16:39:35.030 [0x7f8d44fff700] DEBUG - Codecs: testing h264_qsv (encoder)
Aug 10, 2017 16:39:35.030 [0x7f8d44fff700] DEBUG - Codecs: hardware transcoding: testing API qsv
Aug 10, 2017 16:39:35.030 [0x7f8d46fff700] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Aug 10, 2017 16:39:35.030 [0x7f8d46fff700] DEBUG - Auth: authenticated user 1 as mwc_trexx
Aug 10, 2017 16:39:35.030 [0x7f8d46fff700] DEBUG - Auth: Came in with a super-token, authorization succeeded.
Aug 10, 2017 16:39:35.031 [0x7f8d44fff700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Aug 10, 2017 16:39:35.031 [0x7f8d3e511700] DEBUG - Request: [192.168.0.80:57904 (Subnet)] GET /library/metadata/42194?checkFiles=1&includeChapters=1&includeConcerts=1&includeExtras=1&includeGeolocation=0&includeOnDeck=1&includePopularLeaves=1&includeRelated=0&includeRelatedCount=15&includeReviews=1 (9 live) TLS GZIP Signed-in Token (mwc_trexx)
Aug 10, 2017 16:39:35.031 [0x7f8d44fff700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error
Aug 10, 2017 16:39:35.031 [0x7f8d44fff700] DEBUG - Codecs: testing h264_vaapi (encoder)
Aug 10, 2017 16:39:35.031 [0x7f8d44fff700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Aug 10, 2017 16:39:35.031 [0x7f8d44fff700] DEBUG - Codecs: testing h264_nvenc (encoder)
Aug 10, 2017 16:39:35.032 [0x7f8d44fff700] ERROR - [FFMPEG] - Cannot load libcuda.so.1
Aug 10, 2017 16:39:35.032 [0x7f8d44fff700] WARN - avcodec_open2 returned -1313558101 for encoder 'h264_nvenc'
Aug 10, 2017 16:39:35.032 [0x7f8d44fff700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Aug 10, 2017 16:39:35.032 [0x7f8d44fff700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Aug 10, 2017 16:39:35.032 [0x7f8d44fff700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - Scaled up video bitrate to 6255Kbps based on 1.500000x fudge factor.
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - MDE: E11 - Judge Cuts 4: Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - MDE: America's Got Talent - S12 E11 - Judge Cuts 4: selected media 0 / 44535
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - Streaming Resource: Reducing playback quality for 1904kbps stream bitrate: video resolution to 720x406, audio channels to 2, quality to 41
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - MDE: analyzing media item 44535
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - MDE: E11 - Judge Cuts 4: Direct Play is disabled
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - MDE: E11 - Judge Cuts 4: media must be transcoded in order to use the hls protocol
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - MDE: E11 - Judge Cuts 4: no direct play video profile exists for http/mkv/h264
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - MDE: E11 - Judge Cuts 4: no direct play video profile exists for http/mkv/h264/aac
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - Judge Cuts 4 - video.width limitation applies: 1920 > 720
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - MDE: E11 - Judge Cuts 4: Direct Streaming is disabled, so video stream will be transcoded
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - MDE: E11 - Judge Cuts 4: no remuxable profile found, so video stream will be transcoded
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] DEBUG - Codecs: testing h264_nvenc (encoder)
Aug 10, 2017 16:39:35.033 [0x7f8d44fff700] ERROR - [FFMPEG] - Cannot load libcuda.so.1
Aug 10, 2017 16:39:35.034 [0x7f8d44fff700] WARN - avcodec_open2 returned -1313558101 for encoder 'h264_nvenc'
Aug 10, 2017 16:39:35.034 [0x7f8d44fff700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Aug 10, 2017 16:39:35.034 [0x7f8d44fff700] ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Aug 10, 2017 16:39:35.034 [0x7f8d44fff700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error
