A Chrome extension to keep Plex Web videos in sync with other users
Sync for Plex*
I was bored an made a chrome extension that tries to keep your Plex Web videos in sync with other users.
Important: Make sure to use the html5 player instead of the flash player. To do this you need to go to settings -> Web -> player -> check html5 player
To use the extension:
  1. User A loads and pauses the desired plex media
  2. In the extension click start session, and you will get a session id
  3. Send this id to user B
  4. User B loads and pauses the same plex media
  5. User B inputs the session id and clicks join session
  6. User A is the host and controls the playback of the media
Disclaimer: The direct play videos sync better than transcode videos. Transcoded videos trying to stay in sync with the host may get an error that it cannot play the current media. I plan on fixing this soon.
*Any suggestions on a new name?
Any feedback would be appreciated!
Hey man, id like to test or even help with the source code. But you moved it?
neat idea. I’d wanna give it a go as well. Could you @siirclutch post the updated link, thanks!
