A few pitfalls when using GPU for hardware transcoding
Server Version#: 1.13.5.5291
Player Version#: 5.2
Have been testing my APU and Nvidia GT 1030/1050/1060 for hardware encoding, although the official documentation only mentioned Intel Quick Sync.
Couple of pitfalls:
  • I actually didn’t know GT 1030 can only decode but not encode
  • Some APU or older generations of GPU might actually be capable of hardware transcoding
  • Better use the driver update from device manager itself. I find some versions of drivers might have issue.
  • Even using Windows 10 and disabled integrated GPU, my GT 1050/1060 will only hardware decode if connected to a screen (encode always work) Doesn’t matter whether screen is turned off or not though
  • I tested with most subtitles such as SRT / PGS / SSA, they shouldn’t affect hardware transcoding.
And one more finding when testing direct play from my stream device: Be aware of the combination of video + subtitle + audio when not direct playing
