All of a sudden at least three TV series I’ve had for ages now have issues? I was watching one earlier today, came to watch it again, and it refused to open when I clicked on the series to allow me to resume it.
If I go into the server, there is no art/cover for the three series in question now. If I rescan, nothing changes. Reboot and try again, nothing changes. If I physically remove the series folder and try and tell Plex to delete the series, " There was a problem deleting this item."
If I change a series root folder name and rescan, nothing changes.
So I have them appearing in “TV Shows” with blank covers and cannot even click into them…
If I take the “edit” option, I get, “There was an error editing this item.”
If I go into the Plex client on Windows, an Android phone or LG TV, I get issues with the series too.
What is your server platform?
How full is the hard drive where the Plex data folder is residing?
Did you experience a sudden power outage or hard shutdown of the server machine in the past?
Or inspect them yourself. Take a look at the Plex Media Server.log file and seek for messages about database corrupt or malformed.
If you find these, you may have to repair your database.
So at a DOS prompt I enter:-
“C:\Program Files (x86)\Plex\Plex Media Server\Plex SQLite.exe” “C:\Program Files (x86)\Plex\Plex Media Server\Resources\com.plexapp.plugins.library.db”
…and get up the sqlite console “sqlite>”
I then issue:-
PRAGMA integrity_check;
And get:-
Error: unable to open database file
What am I doing wrong? Why isn’t this all automated option in Plex itself?
The database file is not located in this folder.
Try C:\Users\Parents\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db instead
sqlite> PRAGMA integrity_check;
*** in database main ***
On tree page 43805 cell 13: Rowid 713126 out of order
On tree page 43796 cell 12: Rowid 712808 out of order
On tree page 43781 cell 14: Rowid 712057 out of order
On tree page 43750 cell 63: invalid page number -1627346181
On tree page 43752 cell 11: Offset 41346 out of range 84…1020
On tree page 43752 cell 7: Rowid 710878 out of order
On tree page 43751 cell 11: Offset 6000 out of range 46…1020
On tree page 43750 cell 41: Offset 57464 out of range 338…1020
On tree page 43750 cell 35: Rowid 710643 out of order
On tree page 43750 cell 23: Rowid 709924 out of order
On tree page 43750 cell 9: Offset 62650 out of range 338…1020
On tree page 43750 cell 3: 2nd reference to page 43710
Error: database disk image is malformed
sqlite> VACUUM;
sqlite> REINDEX;
sqlite>
Next it says to:-
“Duplicate the database backup file into the correct directory and then rename them to com.plexapp.plugins.library.db and com.plexapp.plugins.library.blobs.db.”
So I simply:-
copy com.plexapp.plugins.library.blobs.db-2022-07-27 to com.plexapp.plugins.library.blobs.db
and:-
copy com.plexapp.plugins.library.db-2022-07-27 to com.plexapp.plugins.library.db
