Server Version#: 1.13.9.5456
Player Version#: ?? I didn’t get that far yet.
raspberry pi 3
raspbian 8.0 Jessie
Directly after installing I went to the web interface, it automatically goes to setup and then it gives me this error:
A problem has been detected with a core component of Plex Media Server.
I can’t access, settings, etc. When I run sudo service plexmediaserver status I see that it is running fine, however, python has ran into some errors.
pi@raspberrypi3-1:/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs $ sudo service plexmediaserver status
● plexmediaserver.service - Plex Media Server for Linux
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled)
Active: active (running) since Wed 2018-11-14 03:59:39 EST; 31min ago
Process: 26230 ExecStartPre=/bin/sh -c /usr/bin/test -d “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” || /bin/mkdir -p “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” (code=exited, status=0/SUCCESS)
Main PID: 26234 (sh)
CGroup: /system.slice/plexmediaserver.service
├─26234 /bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver “/usr/lib/plexmediaserver/Plex Media Server”
├─26236 /usr/lib/plexmediaserver/Plex Media Server
├─26261 /usr/lib/plexmediaserver/Plex DLNA Server
└─26262 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Reso…
Nov 14 04:00:00 raspberrypi3-1 sh[26234]: File “/usr/lib/plexmediaserver/Resources/Python/lib/python2.7/urllib2.py”, line 94, in
Nov 14 04:00:00 raspberrypi3-1 sh[26234]: import httplib
Nov 14 04:00:00 raspberrypi3-1 sh[26234]: File “/usr/lib/plexmediaserver/Resources/Python/lib/python2.7/httplib.py”, line 80, in
Nov 14 04:00:00 raspberrypi3-1 sh[26234]: import mimetools
Nov 14 04:00:00 raspberrypi3-1 sh[26234]: File “/usr/lib/plexmediaserver/Resources/Python/lib/python2.7/mimetools.py”, line 6, in
Nov 14 04:00:00 raspberrypi3-1 sh[26234]: import tempfile
Nov 14 04:00:00 raspberrypi3-1 sh[26234]: File “/usr/lib/plexmediaserver/Resources/Python/lib/python2.7/tempfile.py”, line 1
Nov 14 04:00:00 raspberrypi3-1 sh[26234]: rary files.
Nov 14 04:00:00 raspberrypi3-1 sh[26234]: ^
Nov 14 04:00:00 raspberrypi3-1 sh[26234]: SyntaxError: invalid syntax
that’s the only error that I can see, the log files looks normal.
plex media server.log: http://termbin.com/x4ir
plex dlna server.log: http://termbin.com/ozud
plex tuner service.log: termbin/qtpr (same termbin url, new users can only post two urls)
if you want the entire log folder zipped up, I can do that.
any help would be great, thanks in advanced.
