A problem has been detected with a core component of Plex Media Server
Server Version#: Latest as of writing
Player Version#: Latest as of writing
I’ve been having the issue with high CPU usage, maxing it out, from Plex Media Server for the past couple of days. Because of this high CPU usage I was unable to watch movies as they would “crash”. Also viewing/editing settings is not possible as it would just timeout in the interface.
So I started examining the logs and found out it was looping with an error “[Time] Failed to convert ‘1970-01-01 00:59:01’ to epoch.”. Also the timestamps of the logs were showing 1970-xx-xx.
Found out that some TV shows/movies were corrupted and were showing the date “1970-01-01” as Last Watched. So I tried fixing that in the database of Plex. this didn’t solve the issue as the dates were overwritten when I started Plex again.
So… I completely reinstalled Plex but now I can’t get past the " A problem has been detected with a core component of Plex Media Server." screen. And again the logs show “Epoch” errors.
Plex is running in a docker container on my Raspberry PI 4. It worked fine for the past 6 months and started behaving like this a couple of days ago.
I have no clue what’s wrong, I attached all logs.
Thanks in advance.
(File removed)
From what I could find, there seems to be an issue with certain container tags causing this kind of trouble.
There’s a post with a temporary fix by switching to a different tag:
Thank you for your quick reply.
It’s fixed now! So there’s a bug in the “latest” build of Plex?
From what I read it’s not so much a bug but some incompatibility with outside dependencies
