I have set up a Raspberry Pi 4 as a remote server but when I try to connect to the server on Plex I get this error message.
Plex Media Server.log (8.1 MB)
I recommend you review the OS updates itself.
I also suggest you check to make sure the system clock is accurate.
PMS is seeing negative time reported.
Apr 24, 1924 06:54:24.-1266196 [0xaa0fa430] DEBUG - NetworkServiceBrowser: PLAYER departed after not being seen for -502025222.375535 seconds: 127.0.0.1
Aug 21, 1927 01:23:24.-1266196 [0xb04fd430] DEBUG - NetworkServiceBrowser: SERVER departed after not being seen for 2.163044 seconds: 127.0.0.1 (raspberrypi)
Aug 21, 1927 02:33:20.-1266196 [0xb04fd430] DEBUG - Notifying the system bundle an update to server /system/notify/serverUpdated?host=127.0.0.1
Jan 01, 1970 00:00:11.-1266196 [0xb04fd430] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/notify/serverUpdated?host=127.0.0.1
Aug 21, 1927 00:53:44.-1266196 [0xb04fd430] DEBUG - HTTP requesting GET http://127.0.0.1:33013/system/notify/serverUpdated?host=127.0.0.1
Mar 20, 1971 02:23:52.-1266196 [0xaa0fa430] DEBUG - player 1lefxb1i5i5u9l3c4r6aosbk was last refreshed -1301190136 seconds ago
Jan 27, 1971 07:29:28.-1266196 [0xb04fd430] ERROR - Error issuing curl_easy_perform(handle): 28
Jan 01, 1970 00:00:00.-1266196 [0xb04fd430] DEBUG - HTTP simulating 408 after curl timeout
Jan 01, 1970 00:00:45.-1266196 [0xb04fd430] DEBUG - [com.plexapp.system] HTTP reply status 408, with 0 bytes of content.
Jan 01, 1970 00:01:10.-1266196 [0xaa0fa430] ERROR - [Time] Failed to convert '1970-01-01 00:00:01' to epoch.
Jan 01, 1970 00:00:00.-1266196 [0xab0fc430] DEBUG - NetworkServiceBrowser: PLAYER arrived: 127.0.0.1
Jan 01, 1970 00:00:22.-1266196 [0xab0fc430] DEBUG - NetworkServiceBrowser: SERVER arrived: 127.0.0.1 (raspberrypi)
Jan 01, 1970 00:02:07.-1266196 [0xab0fc430] DEBUG - Notifying the system bundle an update to server /system/notify/serverUpdated?host=127.0.0.1
Ive updated the OS and checked the system clock is accurate to the correct time but I’m still having the same problem.
The log file looks the same as before:
Plex Media Server.log (327.3 KB)
