A problem has been detected with a core component of Plex Media Server
Server Version#:1.29.2.6364-6d72b0cf6
Player Version#:1.57.1.3358-5fd2a504
Plex Media Server.log (94.9 KB)
Looks like Plex is unable to start one of it’s processes that it needs. Could be a bad install. Try manually running the installer and use the repair option.
i reinstalled plex already and that did not fix it
Can you provide the logs from the “Installer Logs” folder for the last time you installed. It’s the "Plex Media Server_yyy_mm_dd__hr_min_sec.log file.
Plex Media Server_x64_2022_11_21__14_21_42.log (1.2 MB)
The log indicates everything was installed properly. Can you zip up the entire log folder and provide that to me. I’d like to check if there is anything in the other logs that might explain what’s going on.
