A shuffle button in searches
It would be great, when I perform a search, that a shuffle button would appear to play the results.
For example if I search for tracks by a band and see some results, put a shuffle button on the right so I can play them rather than go through a process of making a playlist etc just for an impulsive listen.
Is this about Plexamp or a general suggestion?
I suppose this might apply for search result sections, e.g. per tracks, albums, artists but it’ll be tricky for the entirety of a search result (e.g. mixing movies, shows, seasons, episodes, artists, albums, songs, collections and playlists).
I meant for the main app.
I could see it appearing if I select one of the filters (like Tracks, Movies, Other Videos, etc)
In that case, let’s clarify a bit further.
Filtering
If you filter a library, you should see the library view controls.
Here’s an example from iOS and Plex Web
Searching
There’s no such controls if you search in those apps.
