A way to point Plex to Cloud Storage accounts like Dropbox, Google Drive, etc?
Hello,
Is there a way to link a cloud storage account to your Plex account so it can pull movies/tv/etc-files from whatever you might have in your Dropbox or Google Drive folder? Or whatever cloud storage provider you may use?
Thanks for any feedback.
Have you looked into something like plexguide - plex guide sets all this up for you I think.
You can see the info at https://plexguide.com - I am unsure if or how it works but you could try plexguide.
Thanks for the reply, @Barry_Amerika. I have not heard of that but I will take a look. Since you are pointing me in that direction I’m guessing that there isn’t a simple way to do it through Plex. Looks like a third party workaround I guess.
