Ability to order Playlist films by their named release date
I have created decade playlists for my films in but I need to order those films in chronological release order within the decade. Does this exist? I can’t see the feature anywhere if it does.
This is already possible. Just save this filter in a smart playlist. Keep in mind to set the ordering before you save it.
Thank you so much for this. I didn’t know and it will be a great help.
However, your filter is in the LIBRARY and not the PLAYLIST. Does this apply to the playlists? I’m on iPad at the mo but don’t remember seeing it anywhere on the Mac. When I add a movie to the playlist I’d like it to be moved to the appropriate release year. Otherwise I have been doing it manually which is tedious.
You can save any filter as a “smart” playlist.
A smart playlist doesn’t store the library items, but just the filter criteria.
Which means the smart playlist is auto-updating itself, whenever you add or remove items which fit the filter criteria.
You can also store them as smart Collections instead of playlists. Which is probably the better choice.
Playlists are for playing things one after another.
But in this case you probably won’t do that.
