Ok, I do love Plex DVR and use it quite a lot and most of the time it works great but the other part it doesn’t. I’ve been having issues where recordings are “aborted” for no reason and (most recently) only 5 seconds of the show got recorded. Not exactly the most smooth experience. Am I the only one who has these issues or are others experiencing them as well and are these known issues to Plex and have fixes on the way?
you need to attach log files so they know whats happening
Oh of course! What are the names of the logs I need to send?
go here to find out where to retrieve your files
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
Which ones do I need to send or do I just send the whole zip file?
I don’t know which OS your running but in Windows it would be the file
C:\Users[user name]\AppData\Local\Plex Media Server\Logs\Plex Media Server.log
or if you want to narrow it down around the issue and there are others from earlier times listed as
Plex media server,1,log all the way up to 4. you can check the date modified to get closer to the event.
Thanks! I have attached the logs. This is the case where there was only 5 seconds of the recording.
Plex Media Server.log (245.6 KB)
Can you also let us know what show you were attempting to record, and when it aired?
Was trying to record Australian Ninja Warrior. Sunday 7pm on 9HD Melbourne.
Huh. I recorded that same airing (and I’m in Melbourne too). I’ll look into it
Did it work for you? Also, do you use IceTV or another XMLTV?
Yeah, it worked for me, and I use IceTV for my guide. You’ll need to give me more logs than that though, as that one file only goes back until 11pm last night.
Hmm odd. I’ve attached the whole zip that the Plex web interface downloads for you.
Thanks for your help!Plex Media Server Logs_2018-07-22_23-15-40.zip (2.8 MB)
Huh. In your logs, I see
Jul 22, 2018 20:24:53.740 [4396] DEBUG - DVR:Grabber: Operation for Australian Ninja Warrior - E7 - Season 2, Episode 7 completed with status complete (Success)
Do you see an aborted error in the UI? I do see some transcoding errors, but it doesn’t seem to have stopped the recording.
That’s odd…
Which day is this from?
July 22nd, at 8:24pm
That’s the one where I said only 5 seconds of the show actually got put into my library.
I don’t suppose you have the file so I can see what bit was recorded?
Unfortunately I don’t as I replaced it with a repeat from Yesterday (which recorded fine). The bit that was recorded was in the middle of one of the runs.
Just happened again with tonights episode! I’ve attached the file (in rar) and another log zip. What I noticed was odd is that the episode went into a Season 2018 folder instead of the Season 2 folder that it should be going in.
Thanks for the help!
Australian Ninja Warrior - 2018-07-24 19 30 00 - Season 2 Episode 9.rar (302.1 KB)
Plex Media Server Logs_2018-07-24_21-35-36.zip (3.6 MB)
Edit: Plex isn’t showing tomorrow’s repeat that I’ve been trying to set a recording for in the recording schedule! This is kind of getting frustrating now… Is this still in beta?
