First of all Hello all! I am relatively new to plex and brand spanking new to the plex pass so I apologize for my ignorance at any point during our exchange. Feel free (in fact please do) to point me to relevant documentation. Thanks!
I purchased an HDHomeRun Connect Duo Tuner this weekend and got it all setup in plex. I am able to view the channels and the program guide comes up without any issue. I added a library to plex for my DVR Recordings and then setup MCE Buddy (free) to monitor that directory and convert the .ts files to high quality mkv’s and remove the commercials. Bam I am in heaven everything seems to work great, mostly…
I noticed a couple of times this weekend some of the scheduled programs I had scheduled to record were not recorded it seems. So working under the assumption that it is not a software issue but a configuration issue I rechecked my plex dvr settings, the scheduled recording settings and my MCEbuddy settings. I was able to confirm that PLEX DVR seems to be working (most things are getting successfully recorded), that the scheduled recording is setup to record to the “DVR Recordings” library and the MCE Buddy is configured to watch this path. I also confirmed that the optin in MCE Buddy to “Delete Original” is not enabled. So at this point it would seem I have ruled out a configuration issue, other recordings succeed (in fact most do) and MCEBuddy is performing its magic on them and then dumping the re-encoded file into my TV Shows library.
I started to look at the plex logs and that’s when things start to become fuzzy for me…I am not super familiar with the plex logs or what logs to look in but I decided to give it a shot.
I found this:
Oct 22, 2017 01:41:33.698 [4536] DEBUG - DVR:Grabber: Setting timer to stop grab of ‘Bob’s Burgers - E6 - Sheesh! Cab, Bob?’ in 1407 seconds.
Oct 22, 2017 01:41:33.698 [4536] DEBUG - DVR:Grabber: Waiting for a tuner (2 available).
Oct 22, 2017 01:41:33.698 [4536] DEBUG - DVR:Grabber: Allocated a tuner (1 left)
Oct 22, 2017 01:41:33.698 [4536] ERROR - DVR:Recorder: Error 3 (The recording was aborted) starting the record, shutting things down.
Oct 22, 2017 01:41:33.698 [4536] DEBUG - DVR:Grabber: Freed a tuner (now 2 available)
Oct 22, 2017 01:41:33.698 [4536] DEBUG - DVR:Grabber: Operation for Bob’s Burgers - E6 - Sheesh! Cab, Bob? completed with status error (The recording was aborted)
But nothing here seems to point to an issue that I can start on.
Can anyone point me to something else to look at or some other logs?
Thanks!
