Access content from Pluto TV & Fubi TV
Would it be possible to add Pluto TV live feed to Plex TV live feed?
Also under Movies & Shows add Pluto TV and Fubi TV content, also list both Pluto TV and Fubi TV as a channel?
It’s possible that we might be able to work out some deal like we did with Crackle but can’t make any promises. We are always trying to find new partners.
If you can find the m3u channel links and guide data for Fubi you could use xsteve to get them added to the live TV in Plex. I did this with Pluto but due to the way they add their commercials it did not work since FFMpeg does not support the EXT-X-DISCONTINUITY tag. Not sure if Fubi does the same thing with their commercials as I never tried using them.
Been playing with the different DVR spoof tuners, they are great with adding streaming content in PLEX. The EXT-X-DISCONTINUITY flag is the biggest sore spot on FFMPEG. Also, once I started added more streams, the guide interface started to show its weaknesses. For example, can’t set favorites or sort beyond the HD flag.
I have to say at DisqueTV is great with taking your existing content and making it more of a live tv experience. Using DisqueTV, you can also add you content of (retro) commercials to make it an even more enjoyable experience. I’ve used it to recreate MTV back when then used to play music videos with the MTV bumpers.
List of spoof tuners:
xTeve
DisqueTV
fHDHR (new)
Locast2Plex
I am starting to consider playing with Channels DVR to see if there is a workaround to the EXT-X-DISCONTINUITY tag. Maybe someone can chime in on Channels DVR with streaming content?
Por favor plex seria perfecto si pudieran agregar Pluto TV en alguna parte, ya que es gratuito POR FAVOR!!!
