Can u add tubi or Plutotv as Plex sources on live tv
Server Version#: latest
Player Version#: latest
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Not directly, you have use several apps to make it work. I have been planning on doing it but have not had the time and I will need to check if things have changed since it has been a while since I started the project. xSteve will not work since it uses ffMpeg to transcode the video and it does not support the the format that PlutoTv uses for inserting the commercials.
