Adding the ability to save stations, particularly custom mixes, would be a game changer. Doesn’t have to save the order or anything, just the artists contained within.
Would be nice to have some as ‘presets’ for quick use.
You should in the meantime be able to create playlists from Mixes for you or mixes listed in the Recent Plays hub. You should be able to do the same for other radios/mixes by starting to play them and then save the queue to a playlist.
The same goes for downloading mixes / radios…
