Add Ability to use URL to Match TV shows and Movies
I would like to request the ability to use a URL from IMDB to match TV Series and Movies and the usual match fails to find anything.
You can use the tt number from the URL to match now.
adding to what backfield wrote…
see “Tips” at the very end of this support article – this does not only work with IMDb title IDs…
Thanks! I will give both of those a try
Early 2021 clean-up: implemented (match/fix match using the ID from an IMDb, TMDb or TVDb URL)
