Hello,
I’m using plex (premium) on my NAS Sinology Dj218plus and I want to add a custom agent that a friend give to me (BABS.rar (4.6 KB)). How can I do that ?
Hello,
Would be similar to the installation method listed here https://github.com/ZeroQI/Absolute-Series-Scanner#install--update given that you have filesystem/ssh access to your Synology.
Ok. So I put the file here : /Plex/Library/Application Support/Plex Media Server/Scanners/Series.
and I restart my server.
Is somesing more to do ? Because when I go to setting > agent, I can’t find my custom agent.
I don’t own a Synology NAS but I’d dig around your filesystem a bit to find the Plex Folder. According to the previously linked document it’s probably something along the lines of
Synology, Asustor:
/Volume1/Plex/Library/Application Support/Plex Media Server/
Yes ! I create “Scanners” and “Series” folder and put my scanner inside. But it don’t appear on plex even after a restart.
Can I not just use this ? BABS.rar (4.6 KB). Friends have it and it’s work pretty well.
