Add different Scanner and agent options for single shows
Please add a feature under the advanced edit options in each show. The scanner drop box option only has the option of using the default library scanner. The “plex tv” scanner doesn’t seem to find some of my shows. If I add a new library using “TMDB agent” it finds the show and names them properly. It would be much easier to chose which data I would like to display for each show rather than having to use the same scanner for the whole category. The plex scanner is good for most shows but it still has trouble syncing data from TVDB and sometimes defaults to TMDB for some shows which is the real problem for me.
