Add menu function to harmony one, how to do this ?
Hello all ...
I was using plex with a windows PC, but I gave a try on rasplex with raspberry two days ago and I love it.
Everything works fine out the box.
I use the official 2004 Microsoft MCE IR and a logitech harmony one.
If I well understand, all the navigation keys are not yet supported in rasplex.
but I see the "menu" function (add to queue and others) works on the browser remote, and I can't understand how to set it on my harmony.
I set rasplex in Microsoft/media center computer/MCE remote in the harmony software.
I think the menu key is "m" ... but "m" don't appears in the mapping choice in the harmony software.
The defaut "menu" key on the harmony don't work.
Please, someone using rasplex and harmony could give me a little help ?
Thanks in advance.
Hello all ...
Thanks in advance.
Try having a look at this - page is in German but Google translate does a decent job, may give you some pointers.
http://www.loggn.de/linux-ubuntu-lirc-xbmc-mit-logitech-harmony-steuern-lircmap-xml-und-keyboard-xml/
Regards.
Regards.
Maybe I'm mistaken, but your phrasing indicates that there should have been a site link somewhere in your post, which I can't find.
(It's a mistake easily made in posting. I've done the same thing too, lots of times... ;) )
Best regards: dlanor
Maybe I'm mistaken, but your phrasing indicates that there should have been a site link somewhere in your post, which I can't find.(It's a mistake easily made in posting. I've done the same thing too, lots of times... ;) )Best regards: dlanor
Thanks for the nudge, it was there when I posted, have updated original post.
Regards
thanks both Ned and dlanor.
I will take a look at this and will let you know.
I tryied a lot of configurations in adding MS keyboard, MCE remote, MCE extender remote ...etc in one activity to have all the mapping key, but nothing works, so may be this german page could help.
will se ...
You could try manually learning the key press, myharmony software will walk you through it. Also, if you're using an activity, make sure you update the keypresses in the activity settings and not just the device settings.
