Roku website says Streaming Stick Plus supports 4K HEVC HDR10 video. See Specifications.
Is the video transcoding during playback? If so, what is displayed in the Dashboard (Plex Web → Status).
Wondering why video is transcoding if TV is 4K and Roku supports HEVC 4K.
Make sure you have hardware accelerated transcoding enabled (Settings → Transcoder, Show Advanced). The 4790K cannot decode HEVC in hardware, but it can encode to H.264, so you’ll get half the the transcode accelerated by the 4790K’s iGPU.
Also check the audio stream for transcoding. If possible, choose an audio stream that does not transcode. Audio is always transcoded on the CPU. Usually just a 10% - 20% hit, but if you can avoid transcoding audio it leaves more CPU cycles for transcoding video (such as decoding HEVC).
Note that Plex transcodes all video to 8-bit H.264. HDR information is lost during the transcode, and the Plex transcoder does not support HDR to SDR tonemapping. The net result is that transcoding HDR video results in washed out colors.
Fire up another Plex server on the PC and see how well it works when transcoding HEVC movies.
You should not have to upgrade the processor. A 7th gen Intel processor can decode H265 10bit in hardware.
Reference: Intel Datasheet, Table 2-13. Hardware Accelerated Video Decoding, page 32.
GTX 1050 or better. Limited by Nvidia to two simultaneous transcodes.
Quadro P2000 or better. No fixed limit on simultaneous transcodes.
Older Maxwell cards, GTX & Quadro, with GM206 GPU: GTX 750, 950 - 960, Quadro M2000.
Reference: Video Encode and Decode GPU Support Matrix
