Add photo slideshow Play and Shuffle buttons for FOLDERS not just the entire LIBRARY
Photo slideshows (both with the Play option and Shuffle option) appear to only be available across an entire Library. This is not good. The slideshow Play and Shuffle options disappear once you go into a photo folder within the Library. Nobody is going to add a unique library for every photo folder, so the play/shuffle feature is pretty useless at such a high level when you want to, say, view photos from one soccer tournament or one vacation. There doesn’t appear to be an option to add music to the slideshows either. Plex - please add the Play and Shuffle buttons so that we can run slideshows of specific folders. Just keep them the exact same way you have for the entire library - but within each folder - so that it will do play/shuffle slideshows for all subfolders of the current folder. As a secondary addition, please consider adding a ‘add music to slideshow’ button that can shuffle music from another folder during the slideshow.
