Add RESTART option to PMS
Often when working on PMS remotely I need to restart it but unable to do so.
The only way at the moment to restart the Shield is to power up the device, wait for the projector to power up and select “Restart” option on Android TV.
Perhaps a prompt asking “are you sure” to prevent beginners restarting it by accident could also be included.
Ideally the same command would be run as Android TV’s RESTART function.
thank you in advance
There’s an existing feature suggestion that’s already covering this topic. I suggest you comment/vote in that thread. This should help avoiding duplicate suggestions that’ll distract/disperse attention and votes.
Therefore I’m closing this thread as a duplicate.
