Add TBS-453DX to the NAS compatibility list
@ChuckPa What does this mean? HW transcoding is working as expected?
I tested again today, Jellyfish 400 mbps 4K is literally unplayable on both the browser and my iPhone. But maybe 400mbps is something so big that’s not out there in the real world? Even though the file was only 1.5 GB I thought it should go smoothly, it just doesn’t play at all. I’m not 100% sure what the 400mbps is supposed to represent though. I know my internet connection is about 100mbps, but that’s internet speed - unrelated to video size.
  • On browser: it just buffers for 20 sec then crashes
  • On iPhone, I got once “connection to server is not fast enough”
  • and another time: “The server is not powerful enough to convert this video for smooth Playback.”
Those errors don’t appear in the browser app though (but I guess that’s another issue entirely)
I did see the CPU spike until 100% with that jellyfish video.
Ok, so I tried another Jelly fish, this time I tried a much smaller file that said 80mpbs.
  • even though the title has 80mpbs, the conversion option says 377 mpbs???
  • this file is ALSO not playable at all in the browser it just crashes after 20 sec of buffering.
  • with this file the browser only goes until 40% during the 20 sec of buffering.
Then I try that 80mpbs one on the iPhone and I got the same result as the 400mpbs one.
  • on iPhone I get both “server connection not fast enough” and the “CPU not powerful enough” errors.
  • the CPU of the NAS does spike 100% but playback is not really possible at all, the screen on my iPhone just freezes.
I feel like these files might not be good real life situations to test if everything is working correctly.
I tried a real life 4K film, in the browser, and again I’m surprised by these options I’m seeing:
How come the native 4K is only 4.2mpbs, while the “convert to 1080p HD (high)” is 20mpbs?
Nevertheless - this real life 4K file I have is running smoothly in the browser even when I select “convert to 1080p HD (high)”.
The thing that troubles me though is that the CPU doesn’t seem to do anything:
So my questions are:
  1. Which jelly fish file should I choose to test HW transcoding closer to real life
  2. Did you already 100% determine HW transcoding is working as expected?
  3. Why is transcoding to lower than 4K stating it’s a higher mbps.
  4. Does 200mpbs mean that your internet connection needs to be 200mpbs fast to be able to play the file?
  5. why is my CPU apparently doing NOTHING when I play the real 4K film I have at 1080p with conversion?
  6. Do you recommend I upgrade either my RAM or my CPU?
Here are some more logs from all my tests I did for this post:
Plex Media Server Logs_2020-08-11_10-35-54.zip (2.4 MB)
Let me explain.
  1. “4.2 Mbps” is because of how it scans. Don’t worry about it. The initial scan picks specific frames. At that bitrate, and resolution, the specific frame it selected for initial analysis often shows as less. The i965 chip has “throttling” issues at rates above 100 Mbps. That’s why intel added a new interface in the GeminiLake platforms. Those GeminiLake CPUs should be using the iHD (which is currently not working). If the iHD_video_drv.so (driver) were working, the rate would be accurately shown.
  2. “Transcoding is working” – Meaning that you are accessing the QSV ASIC through the i915/i965 asic pair (both in the CPU). QSV is detected, 2160p HDR decode works.
  3. Caveat The i965 is not rated for sustained bitrates > 80 Mbps. That’s why this is a “workaround”.
  4. The bug with the iHD is simple but not easy to fix. It is required for all Intel Core -9xxx CPUs (CoffeeLake / IceLake). It works for them.
  5. I’m not worried at all about an inital 100% CPU spike. PMS is reading and filling the buffer as fast as it can. Once the output (playback) buffer is full, you see the CPU drop. That’s all 100% expected and perfectly normal because it’s reaching steady state.
  6. Trying to play to a LAN or remote not capable of handling more than 100 Mbps — you get the crazy results. Go back to the Remote Access settings. set your upload limit. Remote devices will have their streams transcoded down to fit within that limit.
Internet speed * 0.8 = total bitrate available (best case). This must include the bitrate of Video , Audio and subtitle track(s) being sent.
So your iPhone was correct. It can’t play at the speed you requested. Notice showed you the maximum of 79.9 ? There’s your hint. 83.3 is perfect / theoretical. Plex is being a bit conservative to account for propagation delays.
Last thing. IGNORE the CPU… 99.999% of the work is being done in the QSV ASIC. The CPU’s job is to read the file, then send out the converted stream when done.
IF it ever does hit 100%, then hardware isn’t working. You’ll know it. HEVC will chew up the entire CPU in a heartbeat
Thanks for all your help ChuckPA.
One last question. If I update Plex will I need to update the preference file manually again each time, or will this fix stay in place?
Hi Plex newbie here…
So yesterday I signed-up to Plex Pass and got PMS running on my QNAP NAS TS-653D. So far i’ve been really impressed and but like others I’m experiencing issues when transcoding. All videos I’ve tried so far work perfectly when direct play/keeping original quality, but the minute I change the quality to auto or anything other than keep original the video either it doesn’t play (via the web, black screen orange rotating circle) or when on my iPhone I get a frozen image and the audio continues to play.
I’m guessing my QNAP (Intel Celeron J4125 quad-core 2.0 GHz) CPU doesn’t have the power to do the transcoding and the hardware acceleration (the Intel HD Graphics 600 GPU) isn’t being used, which is odd because looking in the Dashboard under the ‘Now Playing’ section the video file shows transcode with “(HW)” which one would assume indicates hardware acceleration is being used?
Reading the above I’m assuming the fix here is to modify the Preferences.xml file adding the following text… > VaapiDriver=“i965”
It sounds like a relatively simple fix and workaround, although I’m surprised there’s not a built-in setting option for this as I get a bit nervous editing system xml files.
Before I go ahead and break something can someone please advise/confirm my methods? Thanks in advance.
I’ve been able to complete the procedure for bypassing the iHD driver until Intel releases the fix for it.
Thanks Chuck, it’s working a charm now. Many thanks!
Will this require any future maintenance - i.e. when updating Plex or when Intel release a driver fix?
When Intel releases the formal update and Engineering completes updating the transcoder (check the Release Notes from Plex), you can remove the string using the same procedure.
SUPPLEMENTAL:
QNAP x53DX NAS models (HS-453DX and TBS-453DX) are now provisionally included in the NAS Compatibility Guide.
Hi Chuck, any update from Engineering? Is there an ETA on updating the transcoder?
We are waiting on Intel to release the corrections but we have found a work around for now.
What about the TS-453D?
It’s good. No bypass needed with 1.21.0 +
QNAP NAS Compatibility List section update completed.
Hi @ChuckPa,
I’m still have the VaapiDriver=“i965” code in my Preferences.xml file. I’ve noticed that Q29: How to bypass iHD driver appears to have been removed from your QNAP FAQ page and your last post in this topic states:
Just for absolute clarity, has this issue with the Intel Celeron J4125 CPU (used in the QNAP TS-x53D) been resolved now and therefore is the work around no longer required?
Assuming this code is no longer required, am I to remove it before or after updating PMS. I’m guessing it doesn’t matter either way but wanted to double check as I’m just about to update PMS from Version 1.20.5.3600 to Version 1.21.1.3830.
Thanks in advance.
That’s correct, you no longer need the work-around to force the i965’s driver to be used.
If you have some really exotic older videos, it might produce better quality in hardware but in general application the iHD is better and is also what Intel now supports.
