Adding a library from a WD Home CLoud Duo
Server Version#: 1.18.6.2350
I try to configure plex media server to create a new film library dirctly available from my WD Cloud Home Duo, even if my computer is off.
As i click on the “+”, on the rignt hand side of the “My Cloud Home Duo” , I can select “films” (ie Movies in french), Then I click on “next” button.
The menu “advanced” appears, but i do not have access to “add files” menu.
Could you help me ?
Regards.
Ghislain
The My Cloud Homes have set library paths which you cannot change. if you create a movie library you movies have to be in the existing Shared Movie folder.
Thank you so much to have taken the time for this answer :slight_smile:
Yes, I do understand that there is no need to indicate the location of the movie files : They must be stored in the “PLEX \ Shared movies” folder.
Some files are store there for a long time now … and they do not appear :frowning:
Do you have any idea ?
Ghislain
