Adding foreign subtitles to Game of Thrones
That is a different issue.
see https://support.plex.tv/articles/204985278-account-audio-subtitle-language-settings/
I was checking through some of the other episodes and noticed that part of the subs were working. In episodes 9 and 10 the subs started but then in mid sentences it stopped.
It stopped on which clients?
May I have one of the affected subtitle files, which stops mid-playback?
(Please zip it before dragging it into the message editor here)
Game of Thrones S01E10.eng.forced.zip (457 Bytes)
Game of Thrones S01E01.eng.forced.zip (296 Bytes)
10 has the breaks in the subs and 1 has none of them working.
S01e01 has only 2 lines. One at 00:36:16 and one at 00:52:32
s01e10 has only 7 lines. the last 6 start at 00:31:37
In S01e01 both lines don’t show and in S01e10 4 lines show.
If you open a second browser tab with the Status page, can you determine whether the server is transcoding the video, while you are playing those videos?
(Please try all different clients)
Hello,
I have had similar issues but was able to resolve them except for one point. When I first tried adding Dothraki-only parts I originally set up languages as “Shown With Foreign Audio” for the Subtitle Mode. but I was seeing all dialogue (was pulling subs from the Web). Then I tried “Always Enabled” and inserted the .SRT files into the appropriate Season folder (with the correct name, etc.). This worked fantastic for episodes that had an SRT file associated with it. For episodes that had no Dothraki (and therefore no .SRT file) Plex would pull a subtitle file from the Web and start playing subtitles for all the English parts. This is playing on a Roku.
Playing in Chrome it seems to work OK. For movies with an SRT file I see “ENGLISH (SRT External)” for subtitles in the playback mode. For episodes with no SRT file I see “None” for subtitles. I double checked the Roku for this sub-menu and it is showing “None”, yet it is playing sub-titles. So there is a behavior difference between Chrome and the Roku…Roku is not working right. Please confirm if you see the same…maybe I have a setup wrong but it seems like a bug. Thanks!
